"Lite" usually means Lite on Quality, Lite on Durability and often times means a lighter hit to your wallet but there are real problems and concerns if you go this route. I know. I bought a "Lite" 5th wheel new a year and a half ago and it's falling apart. So far I've had to stain and finish the dinette table, cut 1/4" off one leg of a dinette chair so it doesn't rock, tried to match a stain to hide the paper thin veneer on the MDF cabinets that has rubbed away, re-adjusted interior doors so they would close (wall flexing during towing is the culprit), Put gorilla tape over worn out areas where it rubs when opening/closing the trifold couch (this happened after using it as a bed maybe 20 times), Window treatments falling off etc. Then there's the lack of wall thickness and insulation that not only effects heating and cooling but there's no sound dampening either so you can hear everyone outside and everyone outside can hear you. These are just a few of the issues I've had in the one year of ownership of my "Lite" 5th wheel. Never again!
