laknox wrote:
They said that, if they were to do it again, they'd use these modules instead of the Leaf's. The ones their friends used for their off-grid homestead are 280Ah =each=, and they installed 32 modules, for 29 kwh.
Lyle
not the best idea for your rv, the majarority of thermal runnaway issues have been using the chemistry that they are. there is a reason tesla is starting to switch over to LiFePo4. cheeper to manufactuer plus there not subject to thermal runnaway nearly as bad. I know if two RV's that have burnt down from using tesla packs, and you still need a BMS if you want to treat it as a install and forget battery.
Steve
