laknox wrote:
mikewats wrote:
Need a new battery. I was thinking of a 12V Lithium battery. Not very familiar with them, will my AC/DC inverter 50amp with charging work or will I need a special charger for this type of battery? Any help would be greatly appericated
If you're up to building your own, the Chinese LFP modules are working out very well, according to my cousin who used a Nissan Leaf battery to power their bus conversion. They said that, if they were to do it again, they'd use these modules instead of the Leaf's. The ones their friends used for their off-grid homestead are 280Ah =each=, and they installed 32 modules, for 29 kwh. From what my cousin has told me, for an RV, with only a few modules, you probably wouldn't even need to add a BMS (battery monitor system); not that you =can't=, just not really necessary.
Lyle
This is incorrect unless you never have a hard freeze, LiFePO4 batteries will be permanently damaged by charging at low temp (usual 32F/0C but some go slightly colder) so you need a BMS with low temp charging cutoff.
