rhagfo
Jun 01, 2017Explorer III
MFL wrote:rhagfo wrote:
Well how much clearance do you have above the bed rails? You can do either change, but keep at least 6" between rails and 5er.
You look to be in range of 4" to 6"' nose high or it is the angle of the photo.
Yes, the pic does look like nose is too high. The OP does not give bed rail clearance, but looks to be well over 6"s. If that is the case, you should drop the hitch the final inch first. The Patriot is easy to adjust. Now measure bed rail clearance. If clearance is still more than 6"s, I'd raise the pin box to get as close to level as possible, while keeping the clearance to the 6" minimum.
An inch or two nose high is acceptable IMO.
Jerry
Yes, but nothing feels better than towing level! ??
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
