klr650goldwing's avatar
Jan 30, 2020
Living Room Ceiling Lights
We have a 369RL Solitude and some of the 4-5 inch diameter round ceiling lights that, are rather flat, are burning out. We want to purchase some new bulbs, probably LED, and replace the old ones. However, when I tried to pull the lens off the light fixture to get at the bulb the entire light receptacle pulled down and out of the ceiling. But, the lense did not separate from the fixture. So that is my question; how do I get the lense off the light fixture so I can replace the bulb?
  • Most of the flat fit lights are held in by a butterfly spring system and the bulbs are not replaceable. Try using a putty knife to grip the light and pull down . If it has the spring system, they should come down fairly easy.
  • You can get them on Amazon also. Easier to just replace the whole light.
  • ITC is a huge manufacturer of RV lights. I got exact replacements on Ebay.
  • Most likely, the lenses just rotate not even a quarter turn from the base. If like the led lights I've seen, the entire assembly has to be replaced. No bulb depending on the brand of light.
