Two_Hands's avatar
Two_Hands
Ceiling Lights
My coach has lights flush mounted in the vinyl ceiling. One is out. A tech told me that they pull down for bulb/led replacement. I’ve tried and tried and can’t move this thing. Any suggestions?
  • Ivylog's avatar
    Ivylog
    Explorer III
    Even the ones that are spring mounted...pull down have lenses that twist off. Take a kitchen knife and push the ceiling fabric up to loosen its grip on the cover. Push up and turn CCW on the rim to loosen.
  • ones we had in the Safari
    the whole fixture pulled down
    spring clamp was inside the cabinet bottom
    took me forever to figure them out
  • I don't know if it pulls down or twists but try the doubled over duct tape trick to get a grip.
  • Thanks rgat for the tip. I can’t pull the bulb/lense down or turn it. Can’t get any kind of grip.
  • Some are a twist type lock. Try twisting the cover CCW and see if it comes loose.
