- kaydeejayExplorer
alboy wrote:
You are in BC? I believe that is about the only jurisdiction where exceeding truck GVWR is ticketable.
I knew it would be tight for a SRW ,waiting on Travelling man to get back to me as he has the identical rig,wife is not excited to drive a dually ,im fine with it.
BC RV and Towing regs.
Get a dually!! - alboyExplorerI knew it would be tight for a SRW ,waiting on Travelling man to get back to me as he has the identical rig,wife is not excited to drive a dually ,im fine with it.
- AllworthExplorer IIIf you have to ask, you don't have enough truck!
- Cummins12V98Explorer III"Do yourself a big favor, and just buy a DRW!"
BUT,BUT, It won't go thru the car wash or drive thru or too wide too fit in a parking space............ - alboyExplorerThanks guys,havnt bought the truck yet so may look at having training wheels and not having to watch how we load
- MikeRPExplorer
Travlingman wrote:
I have a 2014 Landmark Savannah and have a 3800 LB. pin, and this is with a loaded weight of 15,580 lbs.
If you look at these empirical results, he’s 24.5 percent on the pin. So Landmark is known to be a heavy hauler.
For my situation with a Cedar Creek 34ik. I’m starting out from dry at 18% on the pin with a 16200 GVWR and a dry weight of 12500.
I will stay at 14500lbs loaded and with this B&W companion slider, my aux fuel tank, I’m going to be right at 3700 lbs payload. So empirical results, at 75% loaded, my 2018 Ram Bighorn 3500 Crew Cab SB SRW HO loaded right now without the aux tank and the load directly over the axle the truck is 42.5in unloaded at the center of the rear wheel and 40 3/8 in loaded. 40 inches is level. I have 8 inches of clearence.
So I may need air bags.
I think this llandmark trailer will need a Duelie. Now you could go with Airlift 5000 ultimate airbags and 19.5 inch Ricksons. You probably would exceed every sticker on the truck and the strick weight constitutionalists would raise the alarm and I’m not recommending this but you could talk to folks who have and get their advice.
The weight would be satisfied but you may need to upgrade the brakes also.
So like many have said, it would just be easier to get a duelie.
Good Luck! - valhalla360Navigator
alboy wrote:
HI LOOKING for loaded pin wt, 16250 GVWR,3130 IS DRY,TRYING to see if i can get by with a srw with a payload of 3800,thxs
That leaves you 670# before you put an ounce in the truck or trailer.
Expect to lose around 200# for the hitch.
Probably another 3-500# added when you load the trailer.
You and the Misses....
Looks like you need more truck if you want to be within the payload limits. - rhagfoExplorer III
What do you really think?
3,800-3,130=670# that is for passenger and all the stuff you carry in the vehicle, I am assuming that your payload includes a full fuel tank.
The dry pin is 23% of GVWR, that will remain or increase based on what you place in the basement. So at max GVWR pin would be 3,737#.
Your payload is only 2,792# so assuming you travel light so half is 1,400# at 23% is 321# of additional pin weight, so now at 349# for hitch and passengers.
Do yourself a big favor, and just buy a DRW! - TravlingmanExplorer III have a 2014 Landmark Savannah and have a 3800 LB. pin, and this is with a loaded weight of 15,580 lbs.
- fj12ryderExplorer III3200-3500 lbs. looks like a good range. Figure the high end and then you'll be golden if it comes out on the low side.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
