laknox
Sep 03, 2018Nomad
jayhardy wrote:
I'm on day 2 of a nice vaca and my refir dies in my 2014 Montana.After getting this Lo-DC message I looked at the battery meter and it is toast. No battery charge. Tried to start refir on propane and that won't work either. AC, microwave work,along with all wall outlets but anything that runs on battery is toast. Battery water levels are good-Any thoughts would be greatly appreciated!!
Batteries can die, even full of electrolyte. Have the battery checked at a shop, where they can charge it, then do a load test.
As mentioned, make sure your disconnect, if you have one, is ON.
Check charging at the battery. If no charging, then your converter could be toast or, like me, might have blown a fuse.
Might want to consider a mobile RV tech to check things out for you. Check https://nrvia.org/ for a certified tech near where you're staying.
Lyle
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
