rodjburge's avatar
rodjburge
Fridge on AC has "Lo AC" Indicator
My fridge seems to be running OK until I put some extra load onto the motorhome electrical system.....such as electric heater or air conditioner. Once the extra load is applied the fridge starts blinking a "Lo AC" code and starts to heat up. Have had to put the fridge on propane (off the AC) if extra heat or cooling of the motorhome are required. Presently setting in an RV park in Phoenix, have not had this problem at previous locations. Is it possible that the voltage supplied at our present location is not adequate to run all of the motorhome systems at one time?? Just trying to figure out if I have an actual problem or if it is a matter of the current facility not supplying the proper power.
Thank you all for the help
