- johntankExplorerThe draw back with this,
1)bike needs to have a center stand
2) needs to have a unrestricted circle the diameter of the length of their bike to be able to turn it around
3) most of the bigger road bikes will be longer than the trailer will be wide on the in side. JMHO - Sprink-FitterExplorer
CaptRick wrote:
Hell Im used to walking the bikes of the bed of my pickup, having just got a toy hauler it will be a breeze to get the bikes out.
To some, it might be easy walking next to the bike, but if you are walking a big bike like a Goldwing and it starts tipping to the side you are not on, most people will not be able to hold it up. - CaptRickExplorerHell Im used to walking the bikes of the bed of my pickup, having just got a toy hauler it will be a breeze to get the bikes out.
- RUFFSTUFFExplorerI just put it in gear and use the front brake and clutch to bring it down. If I could just ride it on out, I would.
bvereshagen wrote:
The Stand Disc looks a lot more reasonable, although IMO backing your bike out with all the weight downhill and the front brake used for control seems a lot safer. I also find it more stable to walk beside the bike on the way down than to sit on it.
I would never walk next to it, straddling it you can balance it, walking next to it you could pop something trying to keep it from going over to passenger side. - fj12ryderExplorer III
bvereshagen wrote:
My thoughts exactly, although I do straddle mine and use front and rear brakes to back down.
The Stand Disc looks a lot more reasonable, although IMO backing your bike out with all the weight downhill and the front brake used for control seems a lot safer. I also find it more stable to walk beside the bike on the way down than to sit on it. - bvereshagenExplorerRe. The Condor: don't the little wheels cause the frame of the loader to high center on the top of the ramp?
- bvereshagenExplorerThe Stand Disc looks a lot more reasonable, although IMO backing your bike out with all the weight downhill and the front brake used for control seems a lot safer. I also find it more stable to walk beside the bike on the way down than to sit on it.
- jdavidsmiExplorerAfter dumping my GoldWing 1500 a second time i Got one of these "Condor CL1000 Cycle Loader" and a 2500lb winch from Harbor Freight. I just walk beside it up or down the ramp.
- RedRocket204Explorer
Sprink-Fitter wrote:
rjxj wrote:
I'm interested in this issue right now because I need to pull a trailer behind my FW with two Yamaha TW200 and a 650 V Star. I wondered about a way to at least spin the v star around or be able to put them on from one side and off the other side like some quads are loaded.
See if they make a centerstand for the V-Star, I can spin my 1800 Goldwing around on the centerstand
TURNCYCLE MOTORCYCLE CENTER STAND DISC
Only aware of it, haven't used.
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 17, 2025
