Backing the truck's rear wheels up onto wheel ramps helps raise the front of the trailer. My concern is that you are increasing the incline of the ramp to the point that it becomes dangerous to drive the cycle up. If the ramp is dry and has an abrasive coating for traction you may be OK. However, when it's wet it really creates a problem. I do not recommend a running start as you could lose control. It needs to be eased up the ramp. That brings us back to the incline of the ramp, especially if loading when it's wet.
Another solution may be to use an addition ramp that can be positioned to contact the trailer's ramp about half way up. A longer secondary ramp of this kind will decrease the incline. You could also elevate the leading edge of the ramp and then use the secondary ramp to get you up to trailer's ramp. That way the incline would be less.
Your problem really seems like a design flaw of the trailer's manufacturer. Maybe the axles are placed to far rearward which makes is harder to get the right incline.
Just some thoughts.
