Justaguy
Oct 13, 2014Explorer
Campinfan wrote:
On mine, even if it is folded toward the door, if you push the door hard enough, it will pop it back out. If you look at the design, it is sort of beveled so it will slide back out if you push hard on it. I tried it on my last rig, even though we had a back door.
Try it from the outside....close the handle then pull straight out on it. IT will jump over the beveled area and open. And testing it this way will not leave a mark on your door.
X2.
I had not thought of this particular situation. So I went out to the 5er and tried it. The beveled end in the closed position will not allow the arm to LOCK against the door.
About Fifth Wheel Group
