Cummins12V98
Nov 28, 2017Explorer III
I only have 5 locks on mine. I drilled out the pins that hold the head on so I could use the small Masterlocks shown they are keyed alike. The 3 larger locks are also keyed alike, the locking handle for the latching system did not need to be drilled out but the two on opposing corners I had to drill out the base latching handles for the larger locks to fit.
The pins that hold the head on should be bent at a 90 to keep them from being able to be pulled thru the holes in the head.
About Fifth Wheel Group
