Lantley
Sep 05, 2014Nomad
shepstone wrote:
I had the same issue with my b&w patriot hitch and 2013 f250 longbed It turns out all i had to do was take the head of the hitch off pull the pins out take the hitch off the rails , turn it around 180 degrees on the rails put the pins back in , put the head back on , swap the spring that levels the head to the new location and now i have about 4" of clearance from tailgate to trailer when hitching up. In other words I guess i had it on back to front
Good idea. I also like using cable to partially lower the gate. V tail gate would be a last resort.
Personally I would have to find a permanent solution.
Dealing with the tailgate should not be a task in itself.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
