fj12ryder wrote:
I don't know if it is even possible for you, but I installed the Dexter EZ-Flex system with wet bolts and couldn't be happier. I doubt it is possible to put it on that trailer without a substantial monetary outlay. FWIW the EZ-Flex system is only a few hundred dollars, but doubtful it is a bolt-on with the Morryde system on there.
IMO the way the Dexter wet bolt kit works is how all trailer suspensions should operate.
What he has on there imho is more Heavy Duty compared to the ez flex. They should have come with the hd wet bolt kit but didn't.
For the OP...
I have a Carriage. See if the center rubber piece is still good, if you go to Morryde site they'll have a pdf to show how to tell (LRE suspension). There is a number stamped in to the rubber to tell which block you have. Changing the block and/ or the HD wet bolt shackles isn't that hard to do I did mine in the field while boondocking. The part of the frame dented I would take to a welding/ fabricicating shop and just weld a patch over the dented area.
