C_B_
Nov 04, 2014Explorer II
Vulcaneer wrote:
Pullrite will wrap around. And once completely engaged, no pull test is needed. It is failsafe by design. It cannot become dis-engaged, unless manually released.
But here's the issue. You really need to be absolutely sure the jaw is COMPLETELY AND FULLY engaged. If it is NOT...your connection is not safe. So for that reason, a good close visual inspection is recommended. And then a pull test.
If you want to buy a hitch so you can avoid a pull test, you might consider a gooseneck. Or get a travel trailer with a ball hitch connection.
PullRite design wraps 140 degrees around the king pin-Totally Enclosing-the pin in the latch. There is only .030" tolerance between the king pin and the latch providing a safe, tight connection.
C.B.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
