Cummins12V98
Nov 09, 2014Explorer III
mobilcastle wrote:
If you are looking to replace your hitch you might want to look at B&W hitches. I have a Companion and it is very easy to hook up or disconnect. It is not a full wrap around but uses two heavy jaws that close around the pin. Good luck with your new hitch.
The B&W does fully enclose around the kingpin with 1" this jaws. And as said earlier there is no reason to do a pull test with a B&W. A simple glance will tell you the jaws are around the kingpin.
Seriously look at the B&W I went from a RBW and I "thought" it was a good hitch. No comparison!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
