cummins2014
Nov 12, 2014Explorer
Cummins12V98 wrote:up2nogood wrote:Cummins12V98 wrote:RAS43 wrote:The Mad Norsky wrote:Mile High wrote:
So how does a truck camper guy come to that conclusion?
First, anyone who has hung around here and reads often can come to the same conclusion.
Second, I don't list everything I RV with. Since you want to know, I've also got a 35 foot Hitchhiker fifth wheel I tow around the country.
Good job!! :B
I came to the conclusion by walking campgrounds for many years and the 3 hitches associated with dropped RV's and damaged beds are REESE by far #1, Husky#2 and Valley #3.
I agree REESE sells more but there is something about the design that makes them more likely than others to have the dreaded dented bed.
You seem to be the only one that has taken a survey of hitches while looking in the back of pickups in campgrounds., and you seem to be an expert on hitch design .So here is some questions for you, what is there about the design of the three mentioned hitches that would cause more drops then a B&W, and what makes the B&W in your opinion so far superior in design.
I will fill you in on my reese hitch, It has a one inch thick wrap around jaw, it closes when backed into, the jaw can be seen in the closed position, the handle is in the closed position , and the locking pin is inserted its hitched. Now not being familiar with the design of the B&W is there some difference in how it operates. Does it close when backed into, or do you have to close it, do you have to insert a locking pin after the handle is closed etc etc. Just curious as to what the B&W does that others don't, and seems to be near impossible to drop a fifth wheel, and no need for a pull test. One other question what is the purpose of being able to LOCK the B&W in the OPEN position .
I don't claim to be an expert. I just know that there is something about the design of the Reese and other similar hitches that have the high handle that make them ore likely to drop. I have been asking what could be the issue for a long time.
Sounds like your design is fairly simple as is the B&W. The B&W has a 1" thick fully wrapping clam shell design. As I back into it the handle and jaws will close. I usually have to push the handle into the fully closed position and then I LOCK the handle closed. Not sure why you can lock the handle open??? I will never do that. One person mentioned they had theirs locked open and drove off and BAM!
I think the simplicity of the B&W's design is a bonus. The biggest thing with any hitch is to really stay focused on your step by step process.
I had a RBW that had a sliding bar that I thought was great until a friend suggested I try the B&W and since I have been very satisfied. If I were to change to another brand it would be the Hensley TrailerSaver with air ride system. They have a similar hitch design that is simple and solid.
Mine is not a clamshell, and yes it is very simple a one piece wrap around jaw, that closes when backed into. The one thing I don't know is if it will stay closed without the locking pin in the handle, and I don't plan on finding out, but if it does come undone with the locking pin out, then that could be a lot of the reason, as you claim, for the reese being the #1 in dropped fifth wheels, and admit that would be a bad design. Clamshell as you call to me means a two jaw that clamps around the king pin from both sides.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
