hmknightnc
Jun 25, 2013Explorer
x2 on more concerned with wieght than length. If it is an older F250 (more than a couple years) you should be looking at a maximum of around 12k# GVWR FW (and that might be too heavy, check your actual truck specs for payload and axle capacity). If it is newer you might be able to get away with 14k# GVWR.
You can find several bunkhouses in that wieght range around 32' however I doubt you will find one with 1.5 baths (you'll like need a dually for that configeration although a modern 1 ton SRW might and I mean might do it)
About Fifth Wheel Group
