ThruTraffic's avatar
ThruTraffic
Looking for Basement Layout Fuzion 301
Used 2014 Fuzion 301
Anyone ever see a layout diagram for this model camper?
Keystone doesn't seem to be interested in responding if one exists so I'm looking farther afield. :-)
I'd like to know where the tanks and other equipment is mounted without cutting open the belly seal. I can find the furnace and water heater but the tanks I just have a general idea.
If you've seen an owners manual I could use one of those too.
  • I think several shoot from the hip. Changes in mid year to current model designs isn't uncommon.
    My complaint is this really makes the vin number useless as a tool to track replacement parts.
  • By the quality of the trailers that I have owned and seen .. I would consider the possibility that they don't build these things based on diagrams or schematics! Like a poster stated above they might be just "winging" it. HAHA
  • I don't know of any manufacturer that will provide schematics.
    Most folks would be really happy with a diagram looking from the top down that showed where the tanks, pipes, crossmembers, and studs are, one looking from the side with something similar, and a set of the same views with basic wiring layouts - with a note that "This is generally how we do it, but your unit may be different". If any manufacturer would provide this, it would really be a first. If those diagrams included a set of measurement references from a common point - say the king pin - it would be heaven.
    As good as Grand Design is, they have been known to provide some information, but a lot of it isn't diagrammed. I needed some help with a wiring item, and they had to go ask the supervisor on the floor. The model was 1 year discontinued, but he remembered roughly where they ran this particular circuit. The info turned out to be helpful.
  • Well Keystone finally responded, and they met my expectations. They sent me a brochure. :-)
  • tmm2good wrote:
    I have a 12 Fuzion 301, Fresh water tank is above the axles. black tank is right below the toilet (in front of the fresh) and the grey tank is in front of the black tank. Hope that helps, I have had part of the bottom cover off mine a little bit looking around. Let me know if you have any more questions about this model, I have had it since new.
    Thank you! Tank locations were the one's I wanted to know about most! :)
  • As far as the owners manual from Keystone, it is VERY generic. I went through mine and wrote down model numbers off of the appliances/generator/etc and went online and searched for the owners manual and printed them out and put them in a binder in my trailer.
  • I have a 12 Fuzion 301, Fresh water tank is above the axles. black tank is right below the toilet (in front of the fresh) and the grey tank is in front of the black tank. Hope that helps, I have had part of the bottom cover off mine a little bit looking around. Let me know if you have any more questions about this model, I have had it since new.
  • I think they just run wires as needed and dont worry too much about routing. As long as everything lights up, they're happy.
  • In all the years I've been using RV.net, the question about model diagrams, schematics, layouts, wiring diagrams, plumbing diagrams have been asked over and over again. Bottom line, RV manufacturers just don't make them available to the public. None do. And in all years I've been using RV.net, none have been successful in finding anything either. It's a secret that RV manufactures seem to keep secret. (at least it appears that way).
    At best, the only types of manuals or diagrams you'll get are from the various appliance in your camper. Those are readily available on the Internet, but the actual build of the RV, is still a deep hole.
    Sorry!
    Maybe, someone else has finally found a crack in the abyss I don't know about. If the manufacturer of your RV won't fork it over, you'll not find it anywhere.
