SkiSmuggs
Mar 06, 2015Explorer
BUDDY1963 wrote:
I have a dodge 1500 4x4 quad cab 5.7l hemi 2013
This doesn't say anything about the load capabilities of your truck. I don't know what options are available for heavy payloads on the RAM, but it is doubtful that you truck has them. Ford's HD Payload is often mentioned as a requirement, but good luck finding one on a dealer lot anywhere. You can only get that by special order.
Please read this:
http://fifthwheelst.com/2015-half-ton-truck-towing.html
And down in the FAQ we find this:
"As evident in the picture (left), we at FWS have determined that for typical RV use, most half-ton trucks do not meet the load requirements for the weight of these trailers. The GVWR and the GAWR will most likely be overloaded, and some driving conditions may be unsafe, even with the lightest fifth wheel RVs touted for half-ton trucks.
However, we have discovered one truck brand that may tow fifth wheel trailers up to 11,712 pounds and not exceed the ratings. That truck is the 2015 Ford F150 with the 3.5L V6 EcoBoost. The configuration that meets this requirement follows: 3.73 gear ratio, 4X2, 163.7" wheel base, SuperCab. With two passengers, the loaded vehicle weight is 5,388 pounds. The GCWR = 17,100 and the GVWR = 7,850. Especially for any half-ton truck, weigh it fully loaded without any trailer attatched and use RV Tow Check 2.0 to calculate the realistic tow capacity."
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
