vr200275's avatar
vr200275
Looking for opinions and advice, please
I have been trying to have an issue with my fifth wheel fixed for about six months now.
I have what I feel is excessive pin box flex.
I have been turned down for warrantee twice by the manufacturer of the fifth wheel and by the frame manufacturer.
It is flexing enough that a seam on the outside is separating and panels in the closet are coming off. Also closet doors are moving when transferring weight from pin to the landing gear.
I have taken some pictures and taken some measurements.
I also have some video but don't know how to post them.
Thanks
  • I sent an email to Primetime Friday regarding the frame flex issue. They have not replied yet. Does anyone know a contact number for Forest River?
  • I had a similar flex issue in 2011, not nearly as severe as yours. Thru a brand specific forum I found another owner with the same issue. I took lots of measurements and photos. I had no visual damage except the closet floor moving ( since it is directly attached to the frame). I went directly to the manufacturer and they brought Lippert in. My dealer provided the service bay and removal/reinstallation of the front cap. A Lippert tech added reinforcement at several spots.
    I know at least 4 units received this repair and the frame design was changed within 6 weeks of identifying the problem. That is how it should work. Post your issue on a Primetime forum and seek other owners. If they have similar problems, then there is a design issue and you will have more leverage. If they don't, then there is a specific defect with your unit that needs to be isolated. Talk directly to Primetime, don't just work thru the dealer. If Primetime won't talk with you, then get a lawyer to send them a letter and post everything on an appropriate forum. Be the squeeky wheel.
  • Dayle1 wrote:
    This document may be helpful. Unfortunately, it lacks any numbers for acceptable vs unacceptable. Lippert doc for flex
    Thank you. I just posted on the Primetime forum. Was able to upload some videos there also.
  • http://www.forestriverforums.com/forums/f210/frame-flex-issue-2015-spartan-1239-a-109052.html
  • One bit of advice would be to make the subject line a little more informative when you start a thread.
    Just saying.
    Turn the damage into your insurance as a claim. The insurance co. will get hold of Rorest River:)
