jimmyfred
May 14, 2013Explorer
gailgold wrote:
I have to admit that I am totally confused re: inside switch/outside switch on the hot water heater. I just picked up my new 5th wheel. Did a rapid walk through at the dealers, and have our first trip out this coming weekend. The switch is set to ön" at the outside water heater compartment. Water system has been primed. So when I hook up, do I turn the inside water heater switch to ÖN" also? I have read the instructions 30 times, and am scared to death to do anything at this point. Yes, this is a very new newbie asking the question.... Thanks! This forum has been SO helpful!
.........The electricial heating element has it's own switch ! The "Other" switch turns on the power to the Igniter to light the propane........it should have a red light that will come on , then go off because there is gas present . If you are out of propane the red light will come on and STAY ON telling you there is NO propane present . , jf
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
