Superbee_Jim
Apr 11, 2017Explorer
My Dexter axle was ruined and I had to replace the entire axle because of lack of lube to the bearings. I just helped 2 of my friends grease there bearings and if you only pump a few times, it will not lube the outer bearings. After you use the bulk of a tube of grease and fill the entire hub cavity and see it coming out the end by the outer bearing, will you know that both bearings have been greased. Both my friends didn't realize that just a few pumps wont do it until grease comes out by the outer bearing. That is what Dexter recommends.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
