John_Joey
Apr 11, 2017Explorer
Superbee Jim wrote:
My Dexter axle was ruined and I had to replace the entire axle because of lack of lube to the bearings. I just helped 2 of my friends grease there bearings and if you only pump a few times, it will not lube the outer bearings. After you use the bulk of a tube of grease and fill the entire hub cavity and see it coming out the end by the outer bearing, will you know that both bearings have been greased. Both my friends didn't realize that just a few pumps wont do it until grease comes out by the outer bearing. That is what Dexter recommends.
^^x2^^
For Dexter axles you need to lift the tire off the ground and spin it while hand pumping grease into the zerk. Once grease comes out then you know the job is done. Using a pneumatic grease gun or just pumping grease in without spinning the tire "might" blow the grease seal.
You may have another issue going on for why the wheel came off though other then grease. You may have had a faulty bearing/race or something completely different like loose lug nuts or undersized engineering.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
