ScottG
Apr 11, 2017Nomad
If you put a few squirts of grease into the never lube zerks it never gets to the front bearing. You have to fill the cavity in the hub before grease will flow outward.
When you have enough grease pumped in you will see it start to come out around the outer bearing. At that point there's a 50/50 chance you have grease on the brakes.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
