Buckeye_ChuckExplorer IIOct 20, 2014low point drains using antifreezeI din not open then recap the low point drains prior to running antifreeze thru the system. Should I have or is it not necessary when using antifreeze?
K_CharlesExplorerOct 20, 2014Our last camper hat valves for the low point drain so no water in the lines. Present camper has caps on the end so lines are full.
Related ContentHouse battery drainLow point drainsLow point drain troublelow points drainlow point drains with antifreeze
