Lemonhead78
Apr 08, 2019Explorer
Low point drain line caps nightmare
So I had to pay someone in October to winterize my camper because my health was really bad. My trailer has 5 drain lines underneath. Some are labeled and some are not. On one side of camper near the hot water tank it has 2 underneath it and says low drain. Their side by side ( touching ) . To the left of that is one labeled fresh tank drain. The guy who winterized left all 3 caps off and put them in the hot water tank access door area. One of the 3 was missing a rubber gasket. I checked Home Depot, a plumbing supply store and even the service department where I bought the trailer. Nobody has this size gasket. They said they will contact forest river and call me back. They haven’t called yet . So here’s my questions please try and help.
The cap is this size and looks similar to this. I can’t see the gasket inside so I’m not sure if it’s the right one or even if it has one. It’s cheap so I tried . You think this is what I need ? Flair-It 16860 Plastic Cap Fitting, 0.5" Size https://www.amazon.com/dp/B000H602C8/ref=cm_sw_r_cp_api_i_Tb5QCb78BXCPB
Second question: on the opposite side of trailer theirs 2 more lines . These are not labeled and he left the caps on these lines. Is their an explanation for why these caps are left on and the others I described above were left off. ? I need some education if you guys don’t mind sparing the time. It’s a surveyor 2016 by forest river
