Buckeye_ChuckExplorer IIOct 20, 2014low point drains using antifreezeI din not open then recap the low point drains prior to running antifreeze thru the system. Should I have or is it not necessary when using antifreeze?
rattleNsmokeExplorerOct 31, 2014Just drain them all the way out. No reason to keep any fluid in there over the winter.
Related ContentHouse battery drainLow point drainsLow point drain troublelow points drainlow point drains with antifreeze
