Buckeye_ChuckExplorer IIOct 20, 2014low point drains with antifreezeDo I need to open then recap the low point drains when using antifreeze or are they just used for draining?
dblrExplorerOct 20, 2014If you are pumping antifreeze thru the lines yes I would close your low point drains.
Related ContentHouse battery drainLow point drainslow point drains using antifreezeLow point drain troublelow points drain
