mamasmax
Apr 08, 2016Explorer
LT tires
A question for you folks who have, or are going to, switch to LT tires on your fiver. Are there certain characteristics that make one tire more desirable than another or will any LT tire be fine? My f...
SabreCanuck wrote:RustyJC wrote:mountainsam wrote:
Are there any professional tire installers in the discussion. I would love to see what they have to say.
Wouldn't that be like asking advice on an RV from an RV salesman or advice on a truck from a truck salesman? Personally, I'd put a lot more stock in the experience of those who USE the tires, not those who SELL them.
JM2CW...
Rusty
Arguably, there are hundreds of thousands of trailer owners out there that are running ST tires and have never had a blowout. So, out of those hundreds of thousands of ST tire owners, most would say "no issues" if you actually got a hold of them to ask.
I guess, like RustyJC, I would be interested to hear from the ENGINEERS as to what the difference is instead of the users who assume all blowouts are the tires problem, replace with different tire and then don't have another blowout... They typically assume it had to be the tire issue and not potentially something else.
Getting a beefier tire could very well be disguising a completely different issue and shouldn't ALWAYS be the answer. Kinda like saying that every single 5th wheel out there HAS TO be pulled with a DRW one ton truck... It's just not the case.There are so many more factors involved in choosing a tire than anyone can really come to terms with.
It would also be interesting to see a survey done on the direct relation of "tire issue" posts compared to "how sharp can I turn" posts from the same user. I'm assuming of course that an ST tire is built to handle the ripping of sharp turns while an LT tire is not. Throw in the "what MPG at 80mph" posts and you really have a debate. But none of us would possibly know that without hearing from the guys that actually build them. Which, I would think is why the question was raised.
Let the debate continue.
