tko9900 wrote:
fj12ryder JIMNLIN What is Sailun inflation pressure? I thought I saw 110 psi. Are wheels stamped or rated for max psi? 1 inch between wheels, seems really close.
ol Bombero-JC My wheels are stamped 6", tire dealer would not put 245's on my wheel.
I have six S637 16" G tires on a tri axle GN stock trailer with 7k axles and keep them 110 psi 24/7 for several reasons.
The benefit of the G tire comes only at those higher pressures. Tire on trailers exhibit ply shear while going around corners or backing into a off angle parking spots. Minimum pressure charts don't take this into account which is one reason tire experts and experienced trailer owners recommend max pressures for tires on a trailer. With 3000-3500 lbs sitting on the tire there is no over inflation.
Some good advise here;
fifthwheelstreet.com
Step #5..
Selecting the Correct Tire Pressure for Your Trailer
We at Fifth Wheel St. no longer recommend adjusting trailer tire inflation pressure below the maximum load PSI rating molded on the sidewall (and only if the wheel/rim is appropriately rated) regardless of the measured scaled weight of individual tire or axle positions for all multi-axle trailers.
However, we do strongly recommend weighing individual trailer tire positions to ensure none of the axles or tire positions are overloaded. Reports have shown that trailers do not have equal weight across all tire positions. Some RV load configurations may reveal as much as 20% difference between the front and rear axle. This especially true for Toy Haulers. It is possible that mismanaged trailer load distribution will cause one end of an axle or a tire to be overloaded. It has been stated, but never confirmed by any RV Weighmaster, that there are many RVs traveling on the road with at least one tire or axle side overloaded. The only way to ensure tires and or axles are not overloaded is to weigh each tire position on your trailer. Unfortunately, attempting to obtain accurate individual tire position weight is practically impossible at all truck scales. View our list of recommend RV Weighmasters here.
- See more at: http://fifthwheelst.com/step5.html#sthash.FIAc3k0Z.dpuf
And from rvtiresafety.com
ply shear.
Spend some time on this tire engineers website for more input about tires on trailers.
If you find a dealer who doesn't want to mount a LT245/75-16 tire on a 6" wide trailer wheel I sure wouldn't trust him to mess with my vehicles tires and wheels.......even my wheel barrow tire.
I ran LT245/75-16 E for years on three of my heavier trailers. Great long term service.
