car2900ExplorerJun 11, 2013Lube plate for Trailair 5th. wheel pin?I have always used a 10" diameter lube plate on all my standard Lippert pins. I just got a Trailair Air Ride kinpin and the plate around the pin looks a lot larger that the standard pins, should I go ...Show More
TheAmRheinsExplorerJul 01, 2013I use the slip plate that is permanently attached to the hitch,never had a problem with it.
Related ContentLicense plates5th wheel plateFifth Wheel Lube Plate ????5th wheel lube plate questionTrailAir TriGlide
