Racine96
Mar 18, 2015Explorer
Lube plate
Question: when using a lube plate, doesn't it prevent the pin from come down further in the hitch? Does it affect how well the pin can be wrapped by the hitch mechanism?
minnow wrote:C-Bears wrote:
Here is the way I look at lube plates. They were invented because folks didn't want to grease the tops of their hitch plates. The grease makes the tops of the plates dirty.
If my hitch manufacturer designed mine for use with a lube plate then it would have been included in my paperwork and I would have been instructed to use it instead of grease.
With that line of thinking, how do you empty your black & grey tanks, hook up your cable TV or change a spare tire as the manufacturer didn't provide a sewer hose, coax cable or lug nut wrench.
