McIntraveler
Apr 05, 2017Explorer
Lube Plate
We're picking up our trailer in 3 weeks and I need a lube plate. I see 10" and 12" plates are available. What size is everyone buying? Thanks.
lostdog wrote:attuco wrote:
I use the 12 inch. Install it, trim if necessary. I also countersink a screw ans drill and tap the box to keep the lube plate from turning.
I believe the entire reason for having a "lube" plate was to reduce friction. It needs to be able to turn to accomplish this.
