McIntraveler
Apr 05, 2017Explorer
Lube Plate
We're picking up our trailer in 3 weeks and I need a lube plate. I see 10" and 12" plates are available. What size is everyone buying? Thanks.
Old-Biscuit wrote:
My lube plate has finders that hold it to king pin....it does not rotate
I hitch up with pin box plate 1"lower then head and let it slide up/into hitch when backing up.
Plate stays in same place
Mine is a 12"
Measure diameter of hitch head for sizing
attuco wrote:
I use the 12 inch. Install it, trim if necessary. I also countersink a screw ans drill and tap the box to keep the lube plate from turning.
