Rwake901ExplorerMar 25, 2019Lube plateI’m new with a fifth wheel, just picked it up on Saturday. I’m sure I’m going to have lots of questions. Should I use the lube plates they make to go between the hitch and the pin? Another question I...Show More
ford_truck_guyNomadMar 25, 2019I see you got your truck problem figured out, what did you end up getting ?As far as the lube plate- yes...clearance - 6" - 8" is good
