Rwake901
Mar 25, 2019Explorer
Lube plate
I’m new with a fifth wheel, just picked it up on Saturday. I’m sure I’m going to have lots of questions. Should I use the lube plates they make to go between the hitch and the pin? Another question I...
Rwake901 wrote:ford truck guy wrote:Rwake901 wrote:ford truck guy wrote:
I see you got your truck problem figured out, what did you end up getting ?
As far as the lube plate- yes...clearance - 6\" - 8\" is good
Bought a new 1 ton Chevrolet 6.0 gas. Did really well towing it home on Saturday.
That's awesome ! Good luck with it.. Did you manage to get the payload figured out? I know you were having issues there for a while...
Payload is ok the hardest thing is seeing with the side mirrors. I’ve got the large trailering mirrors but the fifth wheel is so wide that it’s hard to see behide/beside you. I guess I’ll get used to it. I hope!
