Just bought a TrailerSaver BD3 Hitch for my truck and plan to use a lube plate when pulling my 5th wheel (have not gotten one yet). What would be the best size to get? I see there are 12" and 10" lube...
Hensley Mfg. sells a lube plate designed for your hitch. The tolerance on their hitches are close so you most likely will NOT be able to hook up if you use a standard 1/4" thick lube plate. Hensley's are 1/8" thick and I think 8" diameter. Just give Aaron a call at Hensley and he will fix you up. These are great people to do business with. Good luck.
