clotus's avatar
clotus
lubing axle
I have Dexter EZ-Lube axles. Per Dexter they need to be lubed once a year or 12k miles. I am at my year mark. I have a boat that requires lubing several times, but has a cap that pushes out letting me know it does not need any more lube.
I popped the cap off to look and there is a little grease on the fitting, but there does not seem to be an indicator. How much lube do I pump in? How do I know when to stop? Any suggestions on how to do what I assume will be a very simple task? Thanks!
  • It takes a LOT of grease. Done right it basically purges all the old grease out of the hub thru the front of the hub. I use a red hi temp grease (one of the ones recommended by Dexter). When I see red grease coming out vs the old darker grey colored grease I know it is done.
    Pump slowly with a hand pump. Don't pump too fast. Don't force it. All while continuously turning the wheel. And it will work well. Some have had a problem pushing grease thru the rear seal and ruining the brakes.
    None !... but others will jump in and tell you something different.
    Pull, clean, inspect, repack and adjust brakes.
  • Look at these:
    Dexter
    YouTube
    Google really is your friend it took me 10 seconds to find those and many more.
    Google: dexter ez lube axle maintenance
