tvman44
Jul 22, 2016Explorer
Yes you should be able to see/feel & apply grease with your finger to the bevel gears, as they are not far below the covers. Your plan sounds like what I would do. I do like the dual motor set up. Measuring the voltage at the motor while lifting is also a good idea as you may have a bad connection causing voltage drop somewhere between the motor & battery. :)
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
