Njmurvin
Jul 25, 2016Explorer II
Garyl53 wrote:
I am fighting the same issue on my Lippert landing gear. I was searching for zerks or access points just yesterday but I found none. Please let us know how you make out with his issue. It wasn't obvious how you could pry the top off the legs but I will take another look.
Thanks
Caps were simple to pry off. I put my fingers in there and there was already a hefty amount of grease on the bevel gears. I squirted some more lithium spray lube onto the leadscrew through the holes I had drilled. The jacks still creak and moan on the way up but the strain on the motor is vastly reduced. I will use it this way for a while and monitor closely. I did notice that the gearbox reducer on the drive leg seems a bit loose. The motor is tight against the gearbox, but the gearbox has a bit of play in it where it attaches to the leg and there is some movement when you first push the button and torque is applied. Is this normal?
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
