GASA765's avatar
GASA765
Lug Nut Concerns
We purchased a 2008 FR Silverback 30LSA in Dec to replace our Wildcat that was totaled in an accident back in Oct. We bought new tires and put them on ourselves. Hand tightened without a torque wrench. My buddy has done this many times with his rigs and never had a problem. When we left Pahrump in Feb about 70 miles down the road I looked in my side mirror and saw our driver side front wheel come off our rig. It rolled past us into the desert. The studs had all been sheered off. Towed to a big rig repair facility and had studs for that wheel replaced. The repair facility said to tighten the lugs to at least 175 lbs. Seemed high but I trusted they new what they were talking about. A couple weeks ago I was thinking again this might be too high. I called around and found out they should only be tightened to 100 lbs. I had all 4 manually adjusted to that. A few days ago when we left to come back to Pahrump I was stopping every 50 miles or so to check the lug nuts. About half the stops I had to tighten a couple.
Is this normal? I don't ever recall having ever to do this.
What could be the cause of this? Could a bent axle be causing the studs,to heat up and loosen the lug nuts?
What's the cost of replacing axles?
Someone else thinks the lugs on the other 3 wheels might be worn and need replacing.
Any ideas?
Thanks.
  • different lug nuts have a different taper .
    is it possible that the taper of the lug nuts is incorrect for the wheel that is installed ?
    I change my truck and car wheels twice annually .
    I have snow tires mounted on different wheels .
    I actually have 2 sets of lug nuts for each car that matches the wheels in use .
    a good old fashioned T-Cross lug nut wrench is very handy when swapping out wheels .
    and because I have both the right and left arm involved I can get the lug nuts tight .
    I do have to go back a week after the changeover and retighten the lug nuts .
    there is often 1 that is looser than optimum .
