ol_Bombero-JC
Nov 01, 2014Explorer
Rollnhome wrote:bpounds wrote:
The various macerators seem to work fine (I dont have one). But just because you have a 2" waste line doesn't mean you have to macerate. Your RV will drain fine into a 2" line. Just make up an adapter with fittings from the home center. Might drain just a little slower.
If you need to go a long distance, or uphill, then look at things like the Flojet.
Not good advice. You could very easily plug up the 2" drain.
Yep - why risk *more* work clearing the 2" when Flojet is an inexpensive option..;)
Of course, "inexpensive" is in the wallet of the beholder, LOL!
Flojet for RVs works great - and boaters have been using Macerators for years.
(Flojet mfgs those also).
Easily changes part of the old adage of the two things you need to know to be a plumber!
("Stuff" *will* run uphill)..:W
For more commentary - Search: "Macerator" - *don't* limit the search to fifth wheels. Then do the same in the archives.
LOTS of info available..:C
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
