TXiceman
Sep 05, 2015Explorer II
Freeze up is generally caused by low air flow. Run the fan on HIGH only and check that the inlet side and outlet side are properly sealed. Bypass air will cause a freeze up.
Also check to see that the freezestat or sensor is properly attached or inserted into the coil fins.
Ken
Ken
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
