allcool
Dec 08, 2015Explorer
twvette wrote:
I am taking with me next time I go camping (toy hauler in storage far away) a thermal imager to inspect all wiring and a DC amp clamp to do some more better troubleshooting but wanted to pick some brains of things to look for? I did purchase a 50a circuit breaker that is probably much better than an inline fuse anyway and if nothing else will save me from going through a bunch of fuses.
Good idea getting a circuit breaker and using a amp meter. Get everything on and running/charging to take max amp draw reading. Wonder if the genny running the convertor, and the solar charging system, are both on at the same time and overloading the circuit...?
I have not changed anything on the electrical for a long time now so a bit baffled. There is a solar system (just one panel) and I do have a 2k inverter but nothing gets hot unless the generator is also running.
If the wire to the fuse is not getting hot or melted, but the fuse/ holder is melting, can only be a couple of things.
Either a bad connection between fuse and fuse holder, or fuse/holder is close to the max amp draw it is designed/rated for.
Not uncommon for a fuse holder continuously being used at close to max rated amperage, or one with compromised connections,to get very hot and maybe actually melt a little, I've seen that many times...
jmo
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
