Dakota98
Dec 14, 2014Explorer
All lead acid batteries require water occasionally. Obviously, yours needed it.
Do you have a Battery Discount switch installed? I suspect not.
The battery minder will not put enough amps back into the battery to maintain max charge if the battery is under load.
Install a discount switch & all should be good.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
