davisenvy wrote:
I'm currently looking to purchase a Jayco Eagle HT 29.5bhds. My family needs/wants more room while camping.
First off, I have a 2006 Duramax crew 4x4 to pull the FW. The Jayco has a pin weight of 1,500, dry 8,500, gross weight of 10,000. Anyone see any weight problems?
Second, what can I expect from a FW as far as towing, backing up and overall handling? I have never towed a FW before, but have plenty experience towing TT's.
Third, my truck already has a gooseneck hitch from the previous owner. I plan on getting g the $900 adapter from etrailer. They say this is the safest route without frame damage.
Thoughts and suggestions welcome. The Jayco HT is said to be half ton towable. I would also love to hear from someone that has this model.
Thanks.
First off, that "HT" is b.s. for all but 1 model of F-150, from everything I've read. Figure you could have 2000 lbs on the pin if loaded to max. Yes, it would be rare, but you need to plan for worst-case. With a 2500, you're good to go, IMO. Since the HTs all have the same basic GVW, double-check the cargo capacity. Some of them are pretty anemic, so you may have to be real careful on what you pack with you.
Second, check with Jayco on using a GN adapter. Almost certain that they'd void any frame warranty if you use one. Depending on what GN ball you already have, there are a number of options for you. A "proper" FW hitch would be best and you might be able to find a hitch that uses the GN base already installed. If this is a removable GN ball, and the insert is square, chance are you have a B&W Turnover Ball base. If round, it would likely be a Curt, I believe.
Personally, the Eagle HT 27.5RLTS is on my short list, so I'm learning all I can about it. That CCC I mentioned earlier, is one of the things that does concern me for my use, as does the relatively small black tank, at only 32.5 gallons. I'd give up nearly 13 gallons over my current, smaller, FW. Since we boondock a couple times a year, this is important to us.
As an aside, take a look at the KZ RV Durango 1500 line. Their D284RLT is the other one on my short list. Look at their D286BHD bunkhouse model. Slightly different arrangement inside, but has 2 awnings, for a total of 29' of shaded coverage vs only 21' for the Jayco. Big plus for me, were I interested, especially being in AZ! :-)
Lyle
