JIMNLIN
Apr 23, 2018Explorer III
My son has a 2018 GMC 2500 Dmax shortbed and uses a ancient old rusted 16K Reese manual slider. He bought the hitch used and slide part has never worked/nor needed. The hitch has been on 3 different shortbed 2500 GM trucks of his with two different 5th wheel trailers.
Short bed GM trucks have the longest CA (cab to rear axle) dimension than Ford or Ram. Now add the new gen trailers with a rounded/notched front corner profile eliminates the need for a sliding hitch.
The only hitch I'm aware that has the narrow hitch angle you mentioned is the Superglide.
My '97 16k manual slider will hook and unhook at any angle...even 90 degrees
About Fifth Wheel Group
