MFL
Nov 18, 2021Nomad II
A tire only requires setting according to cold temperature, before towing, or setting in the sun. Yes, towing will add heat/pressure, no problem, if psi is set correctly.
The bigger problem would be way under inflated, from loss of psi, maybe causing tire to heat up/come apart, but then your TPMS should warn you first.
Jerry
Jerry
About Fifth Wheel Group
